Tire Question
Just curious what size tires you guys are running on 20's? My factory tires are P275/55R20 Bridgestone Alenza. My opinion is that this is a heavy vehicle for "P" tires. I am thinking about going to "LT's" - especially during the winter. Any thoughts?
Thanks, Steve |
I have the same stock tires and rims. For the winter, I drpped to 17's with Nokian snows. Nice set up and it goes thru snow like butter.
tires
check out www.tirerack.com enter your car / etc and you get a TON of good info + prices...
i've ordered 4 sets via this now for 3 cars! http://www.tirerack.com/tires/Select...utoModClar=LTZ looks like the people say they like the firestones: http://www.tirerack.com/tires/TireSe...62&tireIndex=0 I like the way these things look! http://www.tirerack.com/tires/tires....utoModClar=LTZ |
Originally Posted by SabrToothSqrl
(Post 122879)
Originally Posted by jeffbco
(Post 122883)
Keep in mind that if you go to LT's and inflate to the proper psi you'll probably get a TPMS light/chime since the pressures will be higher than the programmed thresholds. Dealer can adjust thresholds for you.
I replaced mine with Goodyear Eagle II's 285/50 r20's. But be prepared the Bridgestones have a tread wear rating of 700 (thats really good) most other tires are around 300-400 area. So where you got 60k out of the Bridgestones, you'll get 30k out most other tires.
My wife's 2004 OEM Bridgestones only got about 45K and they were rotated regularly. Replaced w/ BFGs as TireRack shows that they wear better than the 'stones. We'll see.
The OEM tires that came with my 2007 are still in great shape and provide fantastic traction in all conditions. I have never had tires that wore down so slowly.
I don't see any reason to switch or look for something else, unless it is absolutely better in all aspects. SO far, these OEM all seasons have been the best. |
Originally Posted by 73shark
(Post 124890)
BFG Long Trail T/A Tour P265/70R17
