Tire Question
Old Dec 9, 2009 | 3:58 PM
08Z06to09LTZ's Avatar
Default Tire Question
Just curious what size tires you guys are running on 20's? My factory tires are P275/55R20 Bridgestone Alenza. My opinion is that this is a heavy vehicle for "P" tires. I am thinking about going to "LT's" - especially during the winter. Any thoughts?
Thanks,
Steve
Old Dec 9, 2009 | 4:58 PM
08 burb fan's Avatar
I have the same stock tires and rims. For the winter, I drpped to 17's with Nokian snows. Nice set up and it goes thru snow like butter.
Old Dec 10, 2009 | 12:09 PM
SabrToothSqrl's Avatar
Default tires
check out www.tirerack.com enter your car / etc and you get a TON of good info + prices...
i've ordered 4 sets via this now for 3 cars!
http://www.tirerack.com/tires/Select...utoModClar=LTZ
looks like the people say they like the firestones:
http://www.tirerack.com/tires/TireSe...62&tireIndex=0
I like the way these things look!
http://www.tirerack.com/tires/tires....utoModClar=LTZ
Old Dec 10, 2009 | 1:04 PM
jeffbco's Avatar
Keep in mind that if you go to LT's and inflate to the proper psi you'll probably get a TPMS light/chime since the pressures will be higher than the programmed thresholds. Dealer can adjust thresholds for you.
Old Dec 10, 2009 | 8:52 PM
Thanks for the info. I like the Dueller tread design and had similar Bridgestones on my 2500 Duramax. Have any of you gone to LT's on your Suburbans?
Old Jan 2, 2010 | 12:21 AM
addkev's Avatar
I replaced mine with Goodyear Eagle II's 285/50 r20's. But be prepared the Bridgestones have a tread wear rating of 700 (thats really good) most other tires are around 300-400 area. So where you got 60k out of the Bridgestones, you'll get 30k out most other tires.
Old Jan 2, 2010 | 10:27 PM
My wife's 2004 OEM Bridgestones only got about 45K and they were rotated regularly. Replaced w/ BFGs as TireRack shows that they wear better than the 'stones. We'll see.
Old Jan 3, 2010 | 12:01 PM
yarom's Avatar
The OEM tires that came with my 2007 are still in great shape and provide fantastic traction in all conditions. I have never had tires that wore down so slowly.
I don't see any reason to switch or look for something else, unless it is absolutely better in all aspects. SO far, these OEM all seasons have been the best.
Old Jan 3, 2010 | 11:50 PM
addkev's Avatar
Which BFG's did you get? I had BFG AT and I got almost 80k out of those tires. They were awesome.
Old Jan 5, 2010 | 7:59 PM
BFG Long Trail T/A Tour P265/70R17
