tire size
Old Jan 26, 2016 | 6:55 AM
  #11
saabman's Avatar
Hi there;
I am digging out this thread from a while back :-)
I am planning to fit the following to my 2000 1500 Suburban 4WD:
265/65x17 on 17x8 rims with 4.5 backspacing
Do you think it will rub or touch?
Thanks for your input ;-)
Old Jan 27, 2016 | 11:42 AM
  #12
SWHouston's Avatar
The 265's are 8.1" wide, just right for those rims.
Offset is stated in positive or negative, which did you meant by "backspacing".
Do the calculations here...
https://chevroletforum.com/forum/tir...calculator.php
Old Jan 28, 2016 | 9:15 AM
  #13
saabman's Avatar
Hi;
I think by backspacing it is the distance from the inner edge of the rim to the flange contact surface... these numbers I quoted are from the vendor's site... they do not seem to state offset...
Old Jan 28, 2016 | 10:45 AM
  #14
SWHouston's Avatar
Not exactly...
It's the distance (inward or outward) from the flat surface of the hub, to the centerline of the rim/tread.
Read this...
Wheel Tech Information - Offset
Old Jan 29, 2016 | 3:30 AM
  #15
saabman's Avatar
Not exactly...
Read this...
Oh I was reffering to "Backspacing" not offset...
Here is what I have as info:
Old Jan 29, 2016 | 9:26 AM
  #16
SWHouston's Avatar
Have you/can you measure the Offset on your current Rims ?
Old Feb 25, 2022 | 9:20 PM
  #17
Sara@101's Avatar
I have 1995 Chevy Silverado and I'm trying to buy new tires but the tires that are on the truck shows up as wrong size . How to find the correct size for my truck.?
Edit
Old Feb 26, 2022 | 8:38 AM
  #18
repairman54's Avatar
Edit
Sticker inside the driver's door tells you what tire size the truck was built with.
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
slammerslugs
11
Aug 12, 2008 1:48 AM
313hitman
Feb 4, 2008 5:01 PM
WOODDOGG
Jan 29, 2007 11:17 PM
technoswede
Jan 3, 2007 9:15 PM
