Transmission id
I am believe all 5.3L have the 4L60E if you have a half ton vehicle...
The 3/4 ton have the 4L80E....
I don't think the RPO codes will say what transmission is in the vehicle or at least mine does not...
The transmission should have markings on the side but I have no idea if you can see them easily....
I stand corrected :P
the M30 RPO code is the 4L60E
MT1 is the 4L80E....
4L60E -- 4 Speed (M30)
6L80E -- 6 Speed (MYC)
4L80E - 4 Speed (MT1)
LY2 -- 4.8L V8 Non-Active Fuel Management, Iron Block, 2WD
LMG -- 5.3L V8
Active Fuel Management, Iron Block, E85 2WD & 4WD
LY5 -- 5.3L V8
Active Fuel Management, Iron Block, 2WD & 4WD
L92 -- 6.2L V8
Non-Active Fuel Management, Aluminum Block, AWD
LC9 - 5.3L V8
Active Fuel Management, Aluminum Block, E85 4WD Long Wheel Base
4L60E - 4 Speed (M30)
LY6 - 6.0L V8
Non-Active Fuel Management, Iron Block, 2500 Series
LMG -- 5.3L V8
LY5 -- 5.3L V8
L92 -- 6.2L V8
LC9 - 5.3L V8
LY6 - 6.0L V8
Here are 2 other listing I found but they don't link to a particular engine...
MYC
Transmission - Automatic 6 Speed, HMD, 6L80
MYD
Transmission - Automatic 6 Speed, HMD, 6L90
MYC
MYD
Coravir
October 26th, 2019 3:28 PM
DSGB
May 29th, 2013 8:54 AM
