Trying to wire a Power Magic Pro
I own a 2012 LTZ, gasoline Tahoe and run a dash type of camera in my truck that is currently hot all the time. When the truck is shut off the camera will go into a "parking" mode which stops the camera from recording unless there is motion detected. This means that the camera is still drawing power; several weeks ago the truck didn't move for a couple of days and the truck the battery went dead.
To alleviate this issue, I bought a "Power Magic Pro" which when connected to the camera, monitors the battery power and will shut off the power to the camera when the battery power falls to a predetermined level. I've attached a copy of the installation directions below.
The installation requires one wire, the yellow, to go to a always hot line and another, the red wire, to a line that is only hot when the key is turned on. I've checked all the fuses on the drivers side of the dash and these are hot all the time. I found several fuses under the hood that are hot only when the ignition is on, one being #43, Misc Ign (10A).
I don't want to ruin any computer components nor activate an airbag, so this is where my questions start.
The fuse adapters I purchased are rated for a maximum of 10A.
Also mentioned in the directions is that if the vehicle has a "Battery Saver Function, to connect the hot line to the emergency lamps. Any idea if the 2012's have this feature?
- Is there a line inside the cab that I could safely use to hook the Ignition controlled wire (red) to? This is the line that is only hot when the key is turned on
- If nothing inside the cab, would this 10A fuse, #43 be a safe fuse to connect to? If so, any recommendations on how to safely run a wire through the firewall? If possible, I prefer not to make any new holes.
- Are there any full time hot circuits I need to be careful of not to hook this to? Any recommendation on a suitable fuse to connect to on the drivers side of the dash?
barnesam
December 31st, 2022 2:34 PM
nj85z28
July 31st, 2012 12:36 PM
Simplejack
February 7th, 2012 7:28 PM
