Valves won't adjust 97 Tahoe 5.7
Old September 12th, 2011 | 8:03 PM
hsi111's Avatar
Default Valves won't adjust 97 Tahoe 5.7
Hi, Trying to adjust valves on my 97 5.7. I bring cyl 1 to TDC and adjust appropriate valves, turn motor 360 degrees and adjust other set. Every time I turn motor 360 degrees the previous set is loose again. Takes about three adjustments for them to stay tight and then they are too tight. Any Ideas?
Old September 12th, 2011 | 10:03 PM
kevinkpk's Avatar
I'd suggest with each piston at tdc adjust the lifters to mjust touching.
ddillman
March 17th, 2009 10:22 AM
mrsmoos
May 31st, 2008 1:35 PM
Throttle
January 4th, 2008 3:26 PM
maxum
April 23rd, 2007 5:33 PM
