Vibration at 65+mph
Wheel hubs are both new and just had the tires rotated and balanced. There was vibration at all speeds but now there is only a vibration once I hit 65 and faster. Any ideas?
Originally Posted by cyras21
(Post 189966)
Might be a tire w/ tread separation or sidewall bubbly.
You need to have the tires balanced on a machine that can check the Roadforce
Try to outrun the vibration, say 75 mph or better, if the vibe goes away it's balance, if it doesn't, it's a tire problem. Like shark said, it could be tread separation, bubble, or even a shifted belt, etc.
thanks guys.
I know it continues past 80mph...don't really want to take it any faster with all of the speed traps here in VA. I'll have the tires inspected and road force balanced. |
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Specific Conditions Can Affect the Vehicle in terms of Vibration
These are some places to start regarding the vibration. I would recommend contacting the dealership for more assistance. You can contact me either here on the thread or via private message. Please feel free to keep me informed with any further developments regarding the fix. Thank you. Tricia, GM Customer Service. |
All of that + How old are you shockS?
Shocks only dampened road forces up to 60mph. Above that speed and worn shocks cannot dampen wheel hop. Especially on choppy pavement or badly designed roadways. |
tires are good...shocks are original and I have 150,000 miles on the beast. I think it's time for a new set. Should I replace all four? Any suggestions on brand?
(Post 194085)
Just thought of something. How are all the bushings? The ball joints? Wore bushings in the suspension and steering systems, coupled with wore shocks will very likely make more noticeable the slightest of vibrations. |
| All times are GMT -5. The time now is 3:29 AM. |
