VIN Codes
Simply type your VIN number into the box, and hit search. You will then get a fairly large list of numbers and specs about your vehicle. What is nice about this site is that it tells you in "plain english" what all of those numbers (RPO codes) actually mean.
Hope that helps!
Also, here's another Site, where you can type in your VIN #...
Free VIN Decoder - Vehicle Identification Number Report
It's a bit simpler display, which may be preferable to some.
Hope this helps,
S.W.
Hope this helps,
S.W.
found a link for you. Has PDF's of all model year VIN information.
http://service.gm.com/dealerworld/vincards/
Hope this helps,
S.W.
Hope this helps,
S.W.
Welcome to the forum.
Try this: http://www.compnine.com/vid.php
Here's the answer: http://www.compnine.com/vid.php?vin=1GNEC13Z84J208180
Do you not have an RPO Tag/Sticker in your Glove Box ?
If you do, it will probably give you the setup for the specific installs. Here's a few lookups for RPO's. Reason I give more than one, is that not all sites have all the codes, and you may have to look at a couple, to find the right one.
RPO Codes:<O
</O
http://www.montecarloss.com/SSThunder/gmcodes.html<O
></O
http://www.rpocodes.com/<O
></O
http://www.angelfire.com/ny2/96transam/rpocodes.html<O
></O
http://www.gm-trucks.com/rpo-code-lookup/<O
></O
RPO Codes:<O
</O
></O
></O
></O
></O
Greetings Mike, welcome to the Forum !
Just go to the "Home" page at...
Chevrolet Forum - Chevy Enthusiasts Forums - Powered by vBulletin
select a title which most relates to your problem,
click on that, and then click on "New Thread"
and start typing !
Remember, the more information we have about your vehicle
and problem, the better we'll be able to help.
Welcome again,
S.W.
and start typing !
Welcome again,
S.W.
