What tires to put on?
Old June 29th, 2010 | 6:38 AM
vrso2's Avatar
Default What tires to put on?
I'm about to buy new rims and tires for my 07 SUB. The are 22'', but i don't know, what size to get.
My option is 285x45 R22 or 305x45 R22
How's is effect a gas millage ?
Is anybody have some PIC with those sizes ?
here is tires (my opinion)
http://www.tirerack.com/tires/tires....Qty=4&i1_Qty=4
and wheels
http://cgi.ebay.com/ebaymotors/ws/eB...m=250639193418
Thx
Old June 29th, 2010 | 8:47 PM
It will affect gas mileage negatively due to the extra weight.
The 285s might work w/ a little heat gun treatment on the inner fender liners to gain some clearance. 305s probably not.
Of course it all depends on the wheel offset.
Old June 29th, 2010 | 10:13 PM
vrso2's Avatar
here is a Wheel Specifications Model- ACE-001
Size - 22x 9.5
Bolt Pattern -6 x 139.7 ( 6 x 5.5 )
Offset +25
Centerbore to fit -78.1mm
Old June 29th, 2010 | 10:19 PM
vrso2's Avatar
hmmm, im used tire calculator and here is a result:
Looks like, there look at the Overall diameter differences btw original 265x70R17 and 305x45R22. Looks like just a 1.20 inch. Is there possible rubbing ???
<table style="border-collapse: collapse;" background="images/spacer.gif" border="1" bordercolor="black" cellpadding="4" cellspacing="0"><tbody><tr bgcolor="#d3d3d3"><td>Tire 1 - 265/70R17 >Search Tires </td> <td>Tire 2 - 285/45R22 >Search Tires </td> <td>Tire 3 - 305/45R22 >Search Tires </td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Section Width: the width of a tire; the width at its widest point from sidewall to sidewall.';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><td bgcolor="#eeeeee"><table width="280"><tbody><tr><td width="100">Section Width:</td><td align="right" width="80">-</td><td align="right">-</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Section Width:</td><td align="right" width="80">10.43 in</td><td align="right">265 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Section Width:</td><td align="right" width="80">11.22 in</td><td align="right">285 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Section Width:</td><td align="right" width="80">12.00 in</td><td align="right">305 mm</td></tr></tbody></table></td></tr><tr style="background-color: rgb(255, 255, 255);" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Diameter: height of the wheel this tire will fit on';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><td bgcolor="#eeeeee"><table width="280"><tbody><tr><td width="100">Rim Diameter:</td><td align="right" width="80">-</td><td align="right">-</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Rim Diameter:</td><td align="right" width="80">17 in</td><td align="right">431.8 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Rim Diameter:</td><td align="right" width="80">22 in</td><td align="right">558.8 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Rim Diameter:</td><td align="right" width="80">22 in</td><td align="right">558.8 mm</td></tr></tbody></table></td></tr><tr style="background-color: rgb(255, 255, 255);" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Width Range: recommended rim widths that this tire will fit on';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><td bgcolor="#eeeeee"><table width="100%"><tbody><tr><td width="100">Rim Width Range:</td><td align="right" width="80">
</td></tr></tbody></table></td><td><table width="100%"><tbody><tr><td width="100">Rim Width Range:</td><td align="right" width="80">7 - 9 in</td></tr></tbody></table></td><td><table width="100%"><tbody><tr><td width="100">Rim Width Range:</td><td align="right" width="80">9 - 10.5 in</td></tr></tbody></table></td><td><table width="100%"><tbody><tr><td width="100">Rim Width Range:</td><td align="right" width="80">9.5 - 11 in</td></tr></tbody></table></td></tr><tr style="background-color: rgb(255, 255, 255);" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Diameter: overall height of the tire';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><td bgcolor="#eeeeee"><table width="280"><tbody><tr><td width="100">Overall Diameter:</td><td align="right" width="80">-</td><td align="right">-</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Overall Diameter:</td><td align="right" width="80">31.60 in</td><td align="right">802.64 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Overall Diameter:</td><td align="right" width="80">32.09 in</td><td align="right">815.08 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Overall Diameter:</td><td align="right" width="80">32.80 in</td><td align="right">833.12 mm</td></tr></tbody></table></td></tr><tr style="background-color: rgb(255, 255, 255);" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Sidewall: the height of one tire sidewall';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><td bgcolor="#eeeeee"><table width="280"><tbody><tr><td width="100">Sidewall Height:</td><td align="right" width="80">-</td><td align="right">-</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Sidewall Height:</td><td align="right" width="80">7.30 in</td><td align="right">185.42 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Sidewall Height:</td><td align="right" width="80">5.04 in</td><td align="right">128.01 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Sidewall Height:</td><td align="right" width="80">5.40 in</td><td align="right">137.16 mm</td></tr></tbody></table></td></tr><tr style="background-color: rgb(255, 255, 255);" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Radius: height from the center of the tire to the outside edge';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><td bgcolor="#eeeeee"><table width="280"><tbody><tr><td width="100">Radius:</td><td align="right" width="80">-</td><td align="right">-</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Radius:</td><td align="right" width="80">15.80 in</td><td align="right">401.32 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Radius:</td><td align="right" width="80">16.04 in</td><td align="right">407.41 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Radius:</td><td align="right" width="80">16.40 in</td><td align="right">416.56 mm</td></tr></tbody></table></td></tr><tr style="background-color: rgb(255, 255, 255);" onmouseover="style.backgroundColor='#D3D3D3'; window.status='Circumference: distance around the outside edge of the tire';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><td bgcolor="#eeeeee"><table width="280"><tbody><tr><td width="100">Circumference:</td><td align="right" width="80">-</td><td align="right">-</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Circumference:</td><td align="right" width="80">99.27 in</td><td align="right">2521.4 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Circumference:</td><td align="right" width="80">100.8 in</td><td align="right">2560.3 mm</td></tr></tbody></table></td><td><table width="280"><tbody><tr><td width="100">Circumference:</td><td align="right" width="80">103.0 in</td><td align="right">2616.2 mm</td></tr></tbody></table></td></tr></tbody></table>
Old June 29th, 2010 | 10:35 PM
vrso2's Avatar
size 305x40R22 is same overall diameter than OEM 265x70R17.
Old June 29th, 2010 | 11:04 PM
It's the width that will rub. The stock offset for the OEM 20s is +31 mm.
Old June 30th, 2010 | 11:14 AM
AZSCTACO's Avatar
I have 22x9.5 with a +30 offset with 305/45/22 and they do not rub. The overall diameter is a little bit taller so you'll loose minimal on the gas mileage but your speedo will be off by 3%....not a big deal.
For the original question....I recommend Continental Cross Contact. I have a 2nd set on now for my 07 Tahoe and the first set lasted 40K. Love the thread pattern and you can rotate all around.....they are non-directional.
Good luck
Old June 30th, 2010 | 6:36 PM
vrso2's Avatar
Thx dude
Well, ill go with 305x40 R22 which is the same overall diameter, so tacho should show same as original 265x70 R17.
About the tires:
Im looking for summer tires for those 22'' and for 17'' ill buy winter (snow) tires. Are they (Continental Cross Contact) quiet after 20-30k miles ?
Thx
Old July 1st, 2010 | 10:10 AM
AZSCTACO's Avatar
Originally Posted by vrso2
Thx dude
About the tires:
Thx
Yes....very quiet.....just rotate them front to back then from corner to corner every 6-8k and they'll stay quiet and last awhile. Go to onlinetires.com .......I've ordered 6 sets of tires from them and they are reputable and cheeeeeeaaaaap
Old July 1st, 2010 | 5:16 PM
vrso2's Avatar
Is that yours Tahoe in your profile ??? If yes, may you post a pics ? I like yours rims
Quick Reply: What tires to put on?
