Wind noise at back glass
I get terrible wind noise from the back of the suburban even when not towing. if I have the air on at all it whistles. I traced the problem to the rear glass door and the seal. They no longer make contact allowing air to come threw and creating the whistle. Is there a TSB for 2005 models? I have tried to fix this myself but no luck and it drives me nuts lol.
Welcome to the forum
If it was quite before then something has changed, I would suspect the seal has weakened and needs to be replaced...I am not familiar with the 05 but you might also check to see if the glass latch has any room for adjustment... I personally would replace the seal first if no "looseness" is found in the latch assembly
