2000 Suburban Fuel Pump
Suburban stalled a couple of days ago. Thought I ran out of gas. Dumped three gallons in but still couldn't get it started. Noticed when I turned ignition on that I couldn't hear the fuel pump anymore. This is a 2500 with front and rear tanks. Dealers tell me that usually the front tank pump is the one that goes. The rear tank pump just moves fuel to the front tank, and normally they don't fail. Anyone else run onto this? What am I getting into if I try to drop the front tank myself?
With only 3 gallons in it, it shouldnt be that bad to drop. But before you do that crawl under there and give the bottom of the tank a few taps with a rubber mallet then try and see if the pump comes on. If you do end up dropping the tank spray the bolts with PB blaster a few hours before you go to work on it.
Thanks Cooter. Good tip. I already soaked the bolts on the rear tank but then decided that the problem is in the front tank. Any tips on dropping the front? Where are the lines connected? Do I need a special tool t disconnect the fuel lines?
I always put a jack under the tank with some wood to spread out the load then loosen the straps and move them out of the way. Open the fuel door and disconect the filler neck and vent tube. Use the jack to lower the tank a few inches and give you room to disconect the 2 fuel lines and ground strap. You will need a fuel line disconnect tool. The rest of the instructions should come with your new pump or you can create an account on autozone and look at the vehicle repair manual online.
mangomanj
August 17th, 2014 9:51 PM
Keith Moon
November 6th, 2013 10:39 PM
BRB
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
