-   Tracker (https://chevroletforum.com/forum/tracker-26/)
-   -   Drivers door window (https://chevroletforum.com/forum/tracker-26/drivers-door-window-51509/)
sjs514 Jun 29, 2012 3:05 PM
Drivers door window
The drivers side electric window on our 2003 Tracker seems to have a problem-whenever I raise the glass it shifts forward and jams. I have to physically pull it aft so I can continue to raise it up. I took the inner panel off to look at the window and how it sits in the bottom track and it looks fine. Any ideas?
tech2 Jun 29, 2012 7:26 PM
you had the right idea. Sure sound like something is broken in there. Is the glass secure at both mounting points of the regulator? A glass that is secure at both points cannot move or shift without the entire regulator moving also.
Andy Talenda Jul 1, 2012 6:29 PM
GM has a bulletin regarding this issue.Something about having to cut a piece of weather strip. Let me see if I can find it....
Andy Talenda Jul 1, 2012 6:32 PM
Hopefully this will help. Copy and pasted directly from GM Service Information.
I couldn't get the images to come through.
Condition
Some customers may comment that one or more windows binds or tips forward when opening.
Cause
The run channel bracket may be pushing out on the run channel weatherstrip. Refer to the illustration above.
Correction
1. Roll the window to the full down position.
2. Remove the run channel weatherstrip. If the glass has rubbed through the run channel weatherstrip, replace the weatherstrip.
3. Locate the mold mark on the weatherstrip. Refer to the illustration above.
4. Measure 185 mm (7 1/4 in) down from the mold mark and mark the weatherstrip.
5. Measure 40 mm (1 1/2 in) down from the 185 mm (7 1/4 in) mark and remove that portion of the outer lip of the weatherstrip.
6. Using a soap solution, reinstall the run channel weatherstrip.
7. Operate the door glass for proper operation.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
C1042
Weatherstrip, Channel, Front Door Window Run, RH
0.3 hr
C1043
Weatherstrip, Channel, Front Door Window Run, LH
0.3 hr
sjs514 Jul 2, 2012 7:26 AM
Thanks for the info on the GM S.B. Very helpful. Could you send me a link to the bulletin so I could see the illustrations. It would make it clearer to me-I'm not sure what they are calling specific parts. Thanks.
sjs514 Jul 2, 2012 1:14 PM
Actually all I need are the illustrations that go with this bulletin so I can see what specific parts it's referring to. I can give you my email address if you can't post them on this site. Thanks
Andy Talenda Jul 3, 2012 5:24 AM
Here is the link to the PDF file hosted on DropBox. Hope that helps.
sjs514 Jul 4, 2012 7:20 AM
Thanks very much for the link with the pictures-that makes it understandable.
Andy Talenda Jul 4, 2012 8:59 AM
No problem. Glad I could help!
We only have 1 current customer that brings her Tracker in for service, and she hasn't had this issue yet, so I haven't done one, or else I would lend some tips. Good luck, let me know how it turns out!
the-herb420 Mar 3, 2013 2:26 PM
Thank you VERY MUCH!! have been having this issue on my 2002 chevy tracker for years now. Some times the window goes up and down no issues, its the cold weather that really makes it worse. I had GM replace the motor 2 times already as per warranty work. But clearly the assholes knew it wasn't the motor but insisted that was the issue. As soon as I get a mild day to fix it and I`ll post step-by-step pictures of the repair.
Thanks!
