Tracker 1989-2004
Platform: CAMI (Suzuki)
Strut bolt nightmare!!!!
Old Mar 2, 2016 | 10:31 AM
Juggastoned's Avatar
Default Strut bolt nightmare!!!!
I have a 2002 Tracker ZR2, and I'm attempting to take out some rusted strut bolts to replace the front struts. I got an upper off on one side and a lower off on the other. The other two bolts have snapped off flush with the strut, and they aren't budging... I have tried punches, I have tried Seafoam deep creep spray, and I'm actively trying to get an easy out to spin it, because I think it'll punch out if I can break the corrosion. I have a torch and have been trying to heat the knuckle, but I don't know if I am not doing it long enough, or if it's just not helping. I'm at a loss at this point. I know the corrosion is in the knuckle because the strut can move if I pull the other bolt out. Any ideas please!!
Old Mar 2, 2016 | 1:54 PM
I would drill it out. Leave enough bolt so as not to damage the threads. When you get it real close us a tap to get the rest out.
Old Mar 2, 2016 | 2:10 PM
There are no threads to worry about, it slides in and tightens down with a nut on the other side! I'm nearly through one of them.
