-   Tracker (https://chevroletforum.com/forum/tracker-26/)
-   -   Tracker 101: intro to the power window switches (https://chevroletforum.com/forum/tracker-26/tracker-101-intro-power-window-switches-103094/)
L84sky Nov 27, 2020 2:25 AM
https://cimg6.ibsrv.net/gimg/chevrol...fb42918159.jpg
This is a simplified drawing of the power window switches on a 4-door Tracker.
https://cimg1.ibsrv.net/gimg/chevrol...00133f6b76.jpg
Isolate the diagram to just the right rear set of window switches.
https://cimg3.ibsrv.net/gimg/chevrol...532fe38f9b.jpg
At rest, the master switch and the door switch direct a ground signal to both sides of the motor. With no difference in potential, no current flows through the motor and the window is motionless.
https://cimg4.ibsrv.net/gimg/chevrol...ef3283c130.jpg
By moving the rear door switch to the DOWN position, 12 volts is applied to the left side of the motor while ground is still applied to the right. Current flows from left to right through the motor
and the window goes down. When current flows right to left through the motor, the window goes up. Assume dad is commanding the window UP from the master switch and at the same time
Junior is commanding the window DOWN from the door switch. Will the window go UP, DOWN, STOP or blow a fuse?
L84sky Nov 28, 2020 3:17 AM
https://cimg6.ibsrv.net/gimg/chevrol...ac2fb070e4.jpg
Dad's action will supply 12 volts to the right side of the motor. Junior's actions will supply 12 volts to the left side. With no difference of potential, no current flows through the motor and the
window STOPs. The fuse will not blow.
L84sky Sep 29, 2025 2:35 PM
https://cimg5.ibsrv.net/gimg/chevrol...3e2e0a0ffd.jpg
My driver's door window became erratic so I removed the door panel to troubleshoot.
https://cimg2.ibsrv.net/gimg/chevrol...3d717f3f01.jpg
That exposed the master switch connector
https://cimg6.ibsrv.net/gimg/chevrol...95c4f147a9.jpg
I used two jumper wires to manually drive the window up and down so there was nothing wrong with the regulator or the motor.
https://cimg2.ibsrv.net/gimg/chevrol...44f5a7b6d2.jpg
I found a $25 replacement switch online.
https://cimg9.ibsrv.net/gimg/chevrol...fb80806e54.jpg
The new switch has been working flawlessly.
-Nate Oct 2, 2025 11:07 AM
Thanx for sharing and including the important little things as well .
