-   Tracker (https://chevroletforum.com/forum/tracker-26/)
-   -   Tracker wheel options (https://chevroletforum.com/forum/tracker-26/tracker-wheel-options-105045/)
DaveD Apr 13, 2021 4:42 PM
I have a 2003 4 door tracker with 215/75R15 100s General AT2 Grabbers. They work great, no problems there.
I'm not sure I'm on stock alloy wheels or not, so I can't tell you my current offset. So lets assume stock wheels. I have body trim that appears to widen the width of the vehicle and my tires and wheels appear too far in the wheel well.
My wish is to find wheels with more offset pushing my wheels out as if I've added spacers. Part aesthetic correction and partly would like to add width to the track.
I DO NOT want to just add spacers. I would prefer to correct this with new wheels. I'm looking for an additional 1" width per side. A total of 2" to the whole track width.
Are there any recommendations on wheels that would run the AT2s and push the offset out an inch? I wouldn't mind at that rate, getting wider tires as well to make up a portion of the offset as well.
Picture of my wheel below.
https://cimg7.ibsrv.net/gimg/chevrol...e7b8ff91f3.jpg
Mind the sweet rattle can paint job.
Domino3665 Apr 19, 2021 9:56 PM
New Wheels. Plan ‘B’
Have you calculated the cost of new wheels and the labor to swap the tires?
By my estimates, you are at least $600 into wheels alone.
Plan ‘B’.
Keep your current wheels. Go with 225/75-15 tires...like mine. It looks meatier and still let’s you get into more narrow areas. Wider tire are just going to throw muck up the side of your Tracker.
Just a thought. Good luck.
sedrotom Nov 27, 2021 5:42 PM
I like the way these tires fit the 2000 Tracker. Haven't used them much looking forward to better weather.
https://cimg9.ibsrv.net/gimg/chevrol...640d6b4333.jpg
https://cimg0.ibsrv.net/gimg/chevrol...95872a319f.jpg
They ride well on the highway and work fine on logging roads, steep grades, and rocky surfaces.
As advertised ..
