TrailBlazer 2002-2009
02-09 trailblazer A/C
Old Apr 17, 2024 | 8:45 AM
Moparman97318's Avatar
Default 02-09 trailblazer A/C
I have been chasing an issue for about a year with the air conditioning on my wifes 08 trailblazer it has the 4.2 engine. The air just quit working one day so i replaced the pump and checked all fuses and replaced the relay. Still didnt work. I tested the power to the pump no power. Tested the prongs on the relay thats good. But the relay wont trigger to let the clutch kick in unless i ground my test light and touch the relay trigger prong.
Do i just need to trace down ground wires or is it something else.
Old Apr 17, 2024 | 8:54 AM
Welcome from Florida. Did you check the low pressure switch? Try jumping it and see if that helps.
Old Apr 17, 2024 | 10:01 AM
i did try that nothing happened. It only kicks on if i ground the trigger prong on the relay with my test light. The light is very dim when i do this.
Old Apr 17, 2024 | 10:02 AM
is there a low and high pressure switch? I dont usually deal with ac stuff but its the wifes vehicle so she wants it it fixed haha
Margo Gant
Jun 30, 2021 6:52 PM
gamerjake1000
Aug 30, 2016 4:10 PM
bvectra
Jun 29, 2016 4:36 PM
jknight
Oct 27, 2009 4:09 PM
