TrailBlazer 2002-2009
2 problems, AC and shift release
Old Sep 15, 2005 | 9:55 PM
Txsbigfoot's Avatar
Default 2 problems, AC and shift release
I have a intermittent AC problem where the AC will not cool when starting. Sometimes I have to restart the vehicle and it will finally start the compressor. I figure a relay is the problem but dont know which one or where it is.</P>
The other prob is I am having problems getting the brake lock to release the gear shift. Cannot get it out of park when starting vehicle. What up with that?</P>
Thanks</P>
Old Sep 17, 2005 | 3:11 AM
clowninxs's Avatar
i don't know if it can do the same trick for you coz i had a prob once
with my a/c. it's either so warm inside or could freeze you out. but
here goes, check the engagement coil <font size="2" face="Arial, Helvetica">for the air-conditioner compressor clutch, it may not be functioning well enough or probably disengaging.</font>
Old Sep 20, 2005 | 3:51 PM
Patrick's Avatar
how old is your vehicle?
Old Sep 20, 2005 | 6:26 PM
Txsbigfoot's Avatar
I pulled the brake/shift release switch which in mounted on the back of the brake arm and sprayed the contacts. It is now working. I am still having problems with the AC though. The vehicle is a 2003 model.
Old Sep 20, 2005 | 6:28 PM
Txsbigfoot's Avatar
The AC is not having trouble engaging from the clutch. When it gets signal it engages. I hotwired the switch and it pulled in every time. I know there is a relay but dont know where it is.
Old Sep 23, 2005 | 5:00 PM
Patrick's Avatar
any factory warranty left? or maybe it was a common issue?
mowglie
Sep 23, 2014 4:20 AM
b9299
Nov 11, 2008 3:48 PM
LikesTr|_|cks
Jun 29, 2007 6:19 PM
flossinlo
Jun 22, 2007 6:19 PM
SUPERCHIPS TUNER
Sep 15, 2006 12:37 PM
