TrailBlazer 2002-2009
2002 Trailblazer Problem. Help Please?
Old Nov 10, 2013 | 3:50 PM
trucknoob45's Avatar
Default 2002 Trailblazer Problem. Help Please?
hello my 2002 trailblazer driver side window controls stopped working meaning for every window the controls dont work, but if you use the door controls for that indow they work just not the driver side but my locks work and everything ? i rolled them up using it when i got home then the next morning they didnt work help?
Old Dec 6, 2013 | 9:46 AM
marck83's Avatar
Sounds like you may need a new window switch... But check your fuses just to make sure they are good if they are then take your driver window switch out and check the wiring for voltage and check the switch for power as we'll. I'm new to the trailblazer trucks but not new to working on cars lol but if the windows work at their corresponding windows I'm going to say that your driver switch went out. Hope this helps you out and keep me posted on what you find out
Old Aug 16, 2014 | 8:16 PM
jonhamnwa's Avatar
there is a recall on the Trailblazer for the drivers door master switch can cause a vehicle fire after being wet parts will be available in october
pippo047
May 6, 2013 10:18 PM
Sweettaz88
Sep 28, 2012 11:13 PM
