Air conditioner problem and noise
Hello.
I have a trailblazer LT 2006. Since last winter, there is a clicking noise like "drrrrrrr..." inside air-front vents or dashboard only for about 5 sec, starting car or turning it off. When I change the direction of heat or cool air, it sometimes sounds. These days, the cool air does not blow out from front vents no more. OMG!:eek: But, it can do only from floor vent and back seat. Searching the Internet, I am confused because someones are saying the exchange the ac compressor, but others are saying just cleaning the fan under dashboard. In fact, I don't know about car well, so I would like to go to car center to fix it. But, I would like to know the other good way or the exact reason about the problem. And, is it expensive? Please help me!:confused: Thanks for attention. |
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I encourage you to take the vehicle in for an inspection. There may be a blower motor issue. This is just a suggestion, not a diagnosis. A certified technician will be able to offer additional information after an inspection.
Louis GM Customer Service |
Thank you for your help
