TrailBlazer 2002-2009
bumper COVER to remove
Old Jul 29, 2012 | 1:26 PM
pmarc's Avatar
Default bumper COVER to remove
One connection point still to go on a damaged 2007 Chevy Trailblazer LT front bumper cover.
The connect point in question is the bumper end, right in front of the wheel. Note, only the cover needs removal.
I see a plastic module behind the bumper, into which there are 4 clips, or tabs coming off the bumper going into the module. This module appears to be connected to the metal bumper.
I've got the car front raised up 4 inches but don't see how, from top or bottom, to access the module area. [I have only this one area on the ends of the bumper to detach because the other end was removed by the car I hit].
How do I finish removing this bumper? I think I read elsewhere you can use a flat screwdriver to work around the outside of the bumper to slowly dislodge it from the module but I'm wary of trying this. It may break the tabs.
street
May 14, 2015 11:32 PM
Tri5man
Sep 25, 2013 2:18 AM
swoosh1977
Dec 13, 2008 3:50 PM
tracyballard
May 7, 2008 12:39 PM
alexrod
Jan 8, 2007 9:41 PM
