TrailBlazer 2002-2009
A/C leaking in my 2004 TB
Old Aug 19, 2007 | 4:49 PM
TrailBlazerTX36's Avatar
Default A/C leaking in my 2004 TB
Hey there. I own a 2004 Trailblazer and about 3 days ago I noticed that everytime I turn on the AC, the passenger side carpet on the floor gets drenched with water. I wonder what this is caused by anddo I need to take it to the shop or is there something I can do at home to fix this?
Old Aug 28, 2007 | 3:14 PM
bugeyed's Avatar
Default RE: A/C leaking in my 2004 TB
If you can find the evaporator drain hose you can claen it out. I haven't looked at my '04 (just got it yesterday, but the drain hose (rubber) is usually coming out of the firewall into the engine compartment & heading down toward the bottom. That's the hose that makes the big water puddle under the car when you park. If you can't locate it from the engine compartment, run the AC & look under the car & trace the drip. If the hose isn't completely clogged it should still drip a bit. On my Pathfinder I have unclipped the hose from the bottom, lifted it up & blown the debris back into the evaporator. It would be difficult to fully clean the debris out of the evaporator, so blowing it back works for me. BTW the "debris" is usually tree related droppings like those little oak seads that get through the vent ducting.
Good luck & you should take care of this right away. It will not get better by itself & the damp carpet will start to grow mold & smell. Not to mention that usually the efficiency of the AC is impacted.
regards
kevin
Old Jun 8, 2021 | 10:30 AM
hughjd's Avatar
Nice little place in that drain hose for a mouse to get into and fill with trash. look underneath dryer you will see the drain hose. Be best to take cabin filter cover off and see if is filled with trash then blow hose to the outside.
tssiTanker
Oct 26, 2015 4:10 PM
james.reid
Aug 8, 2013 3:17 PM
MX808
Uplander
Sep 6, 2012 5:34 PM
tjokerst91
Aug 28, 2012 10:29 AM
JOEDRAPEAU
Mar 20, 2011 7:31 PM
