TrailBlazer 2002-2009
A/C problem
Old May 16, 2008 | 11:25 AM
enzo31's Avatar
Default A/C problem
got a 02 trail LT .. got problem with the aircond.. when i start the engine and turn on the aircond. the engine stops and turn off .. any idea about this ??? is it a computer issue ??
Old May 16, 2008 | 11:38 AM
enzo31's Avatar
Default RE: A/C problem
ok i got the answer from rBarrios .. 10x alot .. that's was the problem .. but where exactly can i found the throttle ? where is it located in the engine ???
Old May 16, 2008 | 2:35 PM
shawnvw's Avatar
Banned
The throttle is eletronically controlled, it is in the intake manifold right where the breather tube clamps on
Old May 20, 2008 | 11:25 AM
rbarrios's Avatar
you have to remove the big plastic thing on top of the engine that says VORTEC 4200. farily easy to do.
once this comes off... you can see the throttle body.
over on trailvoy.com theres a section with articles oh HOW TO.... in this case how to clean the throttle body.
has a bunch of pictures on how to remove it and clean.
Old Aug 28, 2008 | 6:29 PM
danop's Avatar
hi. I HAVE THE SAME PROBLEM W/ MY TB, 140K AND RUNS GREAT.... DO I HAVE TO CLEAN IT ORI NEED TO REPLACE SOMETHING, I ALLREADY SPEND $200 IN MECH JUSTFOR TRY TO FIND OUT. THANK FOR THE TIPS. DANIEL
Old Aug 29, 2008 | 2:40 PM
rbarrios's Avatar
if you have the engine idle rough or engine shutoff when you turn on AC at idle... then the 1st thing I would do is CLEAN the throttle body. The cleaner cost $5 at auto parts store (Throttle body cleaner).
you cant either remove the entire body to clean throroughly... or leave it on and spray the cleaner in... and move the valve open and close to ffree up built up crud...
This is fairly easy to do... on a scale from 1 to 10.. I give this job a 3.
Rosariods
Jul 21, 2011 8:13 PM
BayAreaChevyGuy
Jan 6, 2011 2:27 AM
chenzo
Mar 21, 2010 5:35 PM
99silver
Feb 2, 2008 4:14 PM
Yesi
Oct 8, 2006 6:27 AM
