low idle
low idle on 2005 trailblaxer ext
For best bluetooth OBD scanners click here
What engine, and what is the idle speed?
Do you have a 'check engine' light on? If yes, check the stored codes first.
Other than that, it is possible that your idle cotrol valve is dirty or stuck. Brake cleaner will help in that case.
Hope that helps.
