TrailBlazer 2002-2009
low oil pressure
Old February 29th, 2012, 9:56 AM
alilin's Avatar
Default low oil pressure
I have a 2003 trailblazer with the I-6 engine. Three weeks ago I noticed the oil pressure drop and the idle slow down when i stopped. Pressure stays up and engine runs ok at town and highway speeds. Changed oil and filter, didn't help. Any ideas before I change the oil pump?
Old February 29th, 2012, 12:13 PM
EinST's Avatar
Welcome to the forum. Specification says the oil pressure should be 12 psi @ 1200 RPM. Oil pressure will go down with the engine speed. You may not have a problem other than the idle speed anomaly.
Old February 29th, 2012, 2:11 PM
alilin's Avatar
Idle speed drops to about 500 to 600 rpm after warmup. Dirty injectors or some other issue? Thanks for replying!!
Old February 29th, 2012, 6:16 PM
EinST's Avatar
The idle speed is not manually adjustable. It may go lower than normal if you happend to have the A/C on (will run automatically with defog or recirc setting) or something with a heavy electrical load. If it bothers you, consider getting it serviced.
usernamehere
August 2nd, 2021 12:07 PM
Eric Sherden
September 24th, 2013 1:21 PM
not_a_car_dude
September 15th, 2013 7:41 PM
MikeShirk
December 31st, 2012 10:39 AM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: low oil pressure
