TrailBlazer 2002-2009
Radio help
Old Apr 27, 2019 | 9:13 AM
kaykin75's Avatar
Default Radio help
I purchased a used 2005 Trailblazer recently and the radio is locked. I literally just left a Chevy dealership where they tried 2 things to unlock it. The 2nd thing worked but the problem is the radio continuously turns on and off...very annoying. I was told it might be a wire issue. I spent $75 for them to unlock it and didn’t want to spend hundreds for them to redo/check the wiring. When the car is on I can’t shut the radio off. I tried turning the volume off and putting the volume to just the back speakers but when it shuts off by itself (every 2 seconds) it goes back to original settings. My question is, how can I disconnect the radio or speakers so I don’t have to listen to it shut on and off? Any input is appreciated...thanks!
Old Apr 27, 2019 | 9:35 AM
kaykin75's Avatar
I will try and take the fuse out and see if that works!
Old May 2, 2019 | 5:19 PM
vipergg22's Avatar
You will lose any audible alarms if you kill the radio so keep an eye on your guages and dash lights.
Old May 2, 2019 | 5:23 PM
kaykin75's Avatar
Will do, thank you!
