TrailBlazer 2002-2009
Starter kicks on with key in OFF position.
Old May 27, 2019 | 5:21 PM
BrettDarty16's Avatar
Default Starter kicks on with key in OFF position.
I have a 2006 Chevy Trailblazer EXT with the 4.2. The engine spun a bearing, so I grabbed an engine from the local salvage yard. The only thing I replaced, was the short block itself. I used the original wiring harness, starter, alt, a/c comp, ext. Once I got everything back in and hooked up, I went to hook up the battery and the starter kicked on with the key in the OFF position. I have checked all my hook ups, grounds, connectors, fuses, relays, and everything looks right.
Any ideas?
Brett 325-669-6942
Old May 27, 2019 | 8:46 PM
Irish_alley's Avatar
I'm here for the party
make sure the wires on the starter are not touching somehow and are not hooked to the same post
Old May 28, 2019 | 7:03 AM
Everything may look right, but obviously there is a wire that is hot all the time hooked up to the wrong post on the starter.
