Trouble with transponder
Hello
I have a Trailblazer LTZ-04, I parked it for a week ago and when i was going to start it today the following problem accord. when i turned the key to start the car the only thing that happened was a relay that clicked, pluss that the security light illuminates and stayed on. There is no other issue then that evrything else is working.
I took my diagnostic tool Autell Maxicheck Pro EU. I used the master key and i got the following code: B3055 No transponder modulation/no transponder.
I have tried to relearn the masterkey with this steps:
1. Turn to the on position without starting the engine.
2. wait approximately 10 min.
3. Turn off the ignition and wait 5 sec.
I have repeated the steps 3 times with no success. the security light illuminates still.
I have then got a new key PK3+ that matches the car.I have tried to relearn that key aswell with no results more then the security light start to flash instead to have illumination. When i run the diagnostic tool with this key the following code appears: B3060 Unprogammed Transponder Identification code recieved.
How should i go on with this problem? is there anyone that has a solution i would be grateful.
