TrailBlazer 2002-2009
what could be causing an ignition misfire?
Old Jun 23, 2017 | 1:24 PM
MAR10's Avatar
Default what could be causing an ignition misfire?
Ive having an issue with something electric, I don't know what to do anymore, I replaced the battery, cleaned off the terminals.. it turns and runs but occasionally won't, goes completely dead as if I didn't have a battery connected...
I went ahead and checked the fuses, and they all seem fine, but with the exception of on missing:# 49 EAP
Old Jun 23, 2017 | 3:11 PM
kevinkpk's Avatar
Does it jump start when this happens, as in just put jumper cables on it, or jump starts with cables on it for a few minutes?
Old Jun 24, 2017 | 8:20 AM
Tis is usually a sign of a loose or bad connection on one of the battery cables. You said you cleaned them but are they tight. Also check both ends of the cables.
