What could be the issue
Sdc111073 , Today 1:38 AM
I'm stumped
I have an 03 trailblazer LT it has 140,000 miles on it runs really well however two months ago I put pads and rotors all the way around and then I put on calipers on the front so let me hold there was some suspension issues a little bit later on down the line whereas my girlfriend was coming home from driving me off at work everyday and the main stabilizer bar snapped from what I can tell and the rate of the the rotors and everything locked up and then for some reason after that the little bit of driving that it did do before we got it where we needed to take it the brakes for rubbing up against the freaking rotors again and I'm not for sure if it's because they were warped or whatever anyway replace the stabilizer bar put all new rotors and pads and calipers around did all that and then I bled the brakes as you're supposed to did all of that make sure there's brake fluid did all of that check check check now I have no brakes what it almost feels like is maybe there's not fluid getting to the to the calipers and stuff so I don't know if it's a freaking sending unit or is the ABS going out or are the lines trashed I'm not for sure I didn't get under there to do some of the work today cuz I was working on another vehicle so I'm not for sure what's going on can anybody give me any insight please she said it first after they've let the brakes and everything it was really hard to push down whatever and it was like it's supposed to be with the resistance then she said as soon as she turned on the key they went to the floor they never built up again or whatever and she said it barely stops the car please in the inside would be welcome
Edit Quote
You may get more responses if you break up that one long run-on sentence and use punctuation. I tried to read it and figure out what the issue is, but after about 3 lines I gave up. It's really hard to read things like that.
nitrochevy
18
Oct 9, 2006 8:15 PM
