Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2015 traverse engine clicking sound?
Old Apr 29, 2023 | 8:04 AM
lacey's Avatar
Default 2015 traverse engine clicking sound?
Hello my engine is making a clicking sound under the cover any ideas what it could be?? I uploaded a video but not sure if it worked….
Old Apr 29, 2023 | 8:33 AM
oilcanhenry's Avatar
Likely lifters going bad or becoming loose, You will have to adjust them.
I never saw a vid, BTW.
Old Apr 29, 2023 | 8:39 AM
lacey's Avatar
I think I got the video uploaded now…
File Type: mov
Old Apr 29, 2023 | 9:57 AM
At what RPM's is this at? It does indeed sound horrible to me.
Old Apr 29, 2023 | 10:39 AM
lacey's Avatar
this is at idle car in park a few minutes after starting it
Old Apr 29, 2023 | 1:35 PM
It sounds to me like a valve train issue, IMHO.. .I would not drive the vehicle until the cause in found out. First thing would be to check your oil pressure. This issue could really damage your engine if it keeps up like this,
Old May 31, 2023 | 12:36 PM
stevenriz's Avatar
Purge Valve will make this noise when hot or getting old. $50 max and very easy to replace. One thing to test is with the cover off and it is ticking unplug the valve right in front of you by squeezing the plug and unplugging it. If ticking goes away, there's your culprit. By now you may have figured this out. Good luck!
Twalter28
Traverse
Feb 14, 2025 2:10 PM
Jesse1
Traverse
May 29, 2020 12:25 AM
Sxren_Colorado15
Jan 27, 2020 2:36 PM
marubal21
Traverse
Sep 20, 2016 2:13 PM
