Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
K&N filter
Old June 7th, 2018, 8:46 AM
Rockyd37's Avatar
Default K&N filter
I bought a 2018 traverse premier and I’m looking to replace the stock air filter with a K&N, but for some reason it’s not listed anywhere, would the K&N part # 33-2394 fit. Thanks
Old June 8th, 2018, 9:04 AM
oilcanhenry's Avatar
It should fit. The thing to watch out for with K&N air filters, is that excess oil can dissipate from the filter and cause issues with the MAP sensor. Not to worry. You simply clean the oil off of the MAP sensor and you should be good to go. I have one on my 4x4 Chevy pickup and its was quite easy to clean it. Runs like a champ.
Old June 8th, 2018, 9:20 AM
Rockyd37's Avatar
Thanks. I figured the 2017 and 2018 are the same engine but on the K&N site there’s nothing on 2018.
The first thing I do is usually pull the stock paper filters out on all my cars,, as far as oil I usually hit them with a air compressor to blow off excess oil the factory puts on..thanks again👍🏻
Old June 10th, 2018, 10:47 AM
the stock oem filters have higher filtering standards than any aftermarket filter. Dirt out is more important that air in. If the stock intake snorkel has a resonator box and you put on a cai without one...you just lowered air flow.
Save your money and leave it stock.
Old June 11th, 2018, 9:52 AM
Rockyd37's Avatar
@tech2
not looking to install CAI I just want to do the K&N stock replacement filter
Old July 9th, 2018, 2:00 PM
julius_raymond's Avatar
Just to confirm, K&N part # 33-2394 fits your 2018 Traverse...? TIA
