K&N filter
It should fit. The thing to watch out for with K&N air filters, is that excess oil can dissipate from the filter and cause issues with the MAP sensor. Not to worry. You simply clean the oil off of the MAP sensor and you should be good to go. I have one on my 4x4 Chevy pickup and its was quite easy to clean it. Runs like a champ.
Thanks. I figured the 2017 and 2018 are the same engine but on the K&N site there’s nothing on 2018.
The first thing I do is usually pull the stock paper filters out on all my cars,, as far as oil I usually hit them with a air compressor to blow off excess oil the factory puts on..thanks again👍🏻
the stock oem filters have higher filtering standards than any aftermarket filter. Dirt out is more important that air in. If the stock intake snorkel has a resonator box and you put on a cai without one...you just lowered air flow.
Save your money and leave it stock.
