Uplander 2005-2009
Platform: U-Body
06 Uplander DTC P0449!! Please Help!! Need Some Advice!!
Old Aug 15, 2010 | 7:39 PM
  #11
joedice711's Avatar
just changed my egr solenoid,engine light still on..what else can it be..please.help
Old Aug 15, 2010 | 7:42 PM
  #12
joedice711's Avatar
sorry gillgs... 06 uplander
Old Aug 12, 2013 | 1:38 PM
  #13
morpheus78's Avatar
Originally Posted by gillgs
hi, i have a 07 uplander had a code of p0449 so after reading a few other threads on this siter I changed the vent solenoid valve located on the top of the gas tank started the vehicle light was off. Then it came back on and now it comes back on as soon as I clear the code within 20 seconds. I spent $120 on the part form GM (i live in Canada) I have checked all the wiring as well and there is power to the solenoid? what else can it be I am getting the same code p0449 and p0449P?? thanks
THERES a sensor at a black house check and replace under the tank!!
Old Oct 29, 2013 | 5:39 AM
  #14
Rebecca Maines's Avatar
New User
Awaiting E-mail Confirmation
Default 07 Uplander check engine light is on
I am a little irritated at the moment. I got gas yesterday morning around 515am and this morning around the same time my check engine light came on. so I tightened the gas cap thinking this might be the problem but the light is still on..........what do I do ??? should I wait a little while longer before calling the dealership ????
Old Oct 29, 2013 | 6:24 AM
  #15
Papa Bear's Avatar
Worn/defective gas cap?
Old Oct 29, 2013 | 7:35 AM
  #16
Welcome to the forum :-) I would wait a bit( a couple of drive cycles) its very possible it was just a not fully seated gas cap. You can try having the code read at an auto parts store and if its an EVAP large leak. It was most likely the gas cap not seated.
Old Oct 29, 2013 | 8:21 PM
  #17
442dude's Avatar
Most auto parts stores will read the code for free - there are 2 separate codes: 1 for a small EVAP leak and one for large.
I agree with the others though...give it a little time as its likely your gas cap.
casey69vwbug
Jan 4, 2012 9:46 PM
Koby5
Oct 9, 2011 8:10 AM
bills 98 wt1500
Jan 30, 2011 6:10 PM
frazercom
Nov 26, 2009 11:47 AM
