Cluster lights
Cluster lights
I just bought a 2007 uplander and so far my wife loves it, but I noticed that not all the dash lights are working. Such as mainly the needles or gauges. Only way they will come on, the lights that do work is if I turn them on, they don’t come on when in auto like they should. It worked one time for about 5 minutes and now nothing, I’ve checked fuses but not sure what else to check. Plus if I wiggle I mean just lightly wiggle the headlamp **** while they are in the on position the headlights will flicker on an off.
on our '06 uplander, the dash lights would sometimes go out completely. i mean ALL of the inside dash lights that are supposed to be on with the headlights. We discovered if we wiggled the **** where you can adjust the brightness of the dash lights, then they'd come on, so i purchased a new headlight switch assembly online and replaced it. Was pretty cheap and easy to replace and it fixed it!
jtcom91
October 23rd, 2019 12:57 AM
slash11
September 19th, 2015 5:34 PM
kellydyane
May 24th, 2014 12:52 AM
dirty paws
July 17th, 2011 4:28 PM
