Uplander 2005-2009
Platform: U-Body
Driver Side Window Malfunction
Old Jan 31, 2024 | 3:34 PM
whyme6181's Avatar
Default Driver Side Window Malfunction
2005 Chevy Uplander 90000 miles
My driver side window will not roll up all the way. When you try to roll it up it will go to a certain point and then kind of click like it wants to go up higher but it won't. The same thing happens when you roll it down. It goes all the way down, but then clicks as if there is farther to go. I have already replaced the actuator and motor for the window, because before that the window wouldn't close without a gap. Now the window closes without leaving a noticable gap, but there is enough of a gap to produce a lot of wind noise. Also it seems the more I roll the window down the bigger the gap gets. I have resorted to rolling the window up as much as it will go and then manually pulling the window up the rest of the way. However, when I do this the window won't go down without manually pushing the glass down. Any ideas on how to get this fixed for good?
Old Jan 31, 2024 | 4:12 PM
window regulator has either jumped or broken tooth/teeth
Take off the door panel and inspect.
Replace/repair the assembly as necessary.
service manuals are on charm.li
Old Jan 31, 2024 | 5:50 PM
whyme6181's Avatar
This is happening after the assembly was replaced. We took out the old one and replaced it with
Front Power Window Regulator w/ Motor Set Driver Side Left LH for Chevy Pontiac
Old Jan 31, 2024 | 11:22 PM
whyme6181's Avatar
Here is a picture of what I am referencing in my previous reply:
Hnagle3054
Sep 24, 2024 8:52 AM
proshadessd
Dec 23, 2021 12:18 AM
justin69
Feb 28, 2015 2:54 PM
highroad
Dec 6, 2014 11:18 AM
98greenventure
Apr 1, 2007 3:15 PM
