Uplander 2005-2009
Platform: U-Body
Glove box hinge 2007 Uplander
Old Oct 22, 2011 | 6:57 PM
  #11
Papa Bear's Avatar
$500.00 to repair a broken glove box door. That's obscene !! Vulgar !!
The last new GM I bought before the 2007 Uplander was a 1970 Bonneville. The only way to punish a Corp like that is wait another 37 years to buy another one...
Old Apr 17, 2012 | 7:07 AM
  #12
bigfastredcars's Avatar
Thumbs up Glove box hinge 2005 2007 Uplander
i have 2005 to 2007 Glove box hinge chevy Uplander for sale on ebay
Old May 16, 2012 | 5:09 PM
  #13
tchamp's Avatar
Default how to replace?
I have the same problem. hinge broke. I just bought a new one off eBay.
I can't get the bottom part of the broken hinge off. It appears to be riveted on. Any good ideas on how to do it without breaking more things than necessary?
I tried just prying them off like the plastic panel clips, but no go.
Old May 17, 2012 | 6:33 AM
  #14
Default cant get off
you have to cut them off with a pair of wirecuters our drill them out i used wire cuters
Old May 17, 2012 | 7:46 AM
  #15
tchamp's Avatar
so then what kind of fastener do you use to put back on after the rivets are gone?
Old May 17, 2012 | 9:57 AM
  #16
johntaps's Avatar
Former Sponsor
Post how to replace?
Wrap a flat-tip screwdriver with protective tape, and apply protective tape around the related parts to prevent from damaging, while carrying out the procedure for removing bottom hinge. Insert a flat-tip screwdriver in the notch of the cap and release the hooks by prying up the cap.
Old Sep 1, 2012 | 4:59 PM
  #17
cbain@shawbiz.ca's Avatar
Default Glove Box repair
These items are of poor design. Until GM issues a recall for this obvious manufactures defect any new or used gloveboxes will fail. I was able to fix the thin plastic hinge with a metal piano hinge. I have included pictures. The "inside" uses very small screws so as to not poke through the front of the door. I had to use a small stip of metal over the piano hinge so that these tiny screw heads would not go through the piano hinge. These screws are so small, they can go in without a pilot hole. On the bottom, I used machine screws #10 half inch. Here I used pilot holes. There is lots to hold on to on the bottom and 4 screws seems to do it. I did not remove any of the black plastic as that is what is holding the screws. The glove box looks as if it never broke. You would have to be on the floor to see the hinge.
Attached Thumbnails Glove box hinge  2007 Uplander-uplander-glovebox-bottom.jpg   Glove box hinge  2007 Uplander-uplander-glovebox-inside.jpg
Old Oct 8, 2012 | 1:06 PM
  #18
dmbze's Avatar
I used a thin layer of heavy duty black duct tape on the hinge instead of the gorilla tape. Works well. Now I wonder though about the lock part. I think that may need replaced as door will not stay shut.
Old Nov 2, 2012 | 8:55 PM
  #19
Crystal Detling Scatterday's Avatar
Do you still have this item? If you do please contact me at cscatter@hotmail.com. I would like to buy the glove box.
Old Sep 4, 2018 | 8:33 PM
  #20
SkookumB's Avatar
I managed to fix mine really cheap in an hour. Used a piece of strong fabric as a hinge. Put it inside the bracket so you can't see it's there. Works mint.
mackda600
Jul 22, 2010 7:19 AM
rurban2
Apr 5, 2010 7:03 PM
tedsfam
Aug 2, 2009 2:59 PM
Sheepdip
Apr 8, 2009 12:59 PM
northey87
Jan 5, 2008 9:11 AM
