Uplander 2005-2009
Platform: U-Body
Lowbeam adjustment
Old Jan 29, 2012 | 11:22 PM
BigDawg's Avatar
Default Lowbeam adjustment
Just wondering if the allen screw behind the seal is the horizontal or vertical adjustment Whats got me is the screw looks like it adjusts the highs. None of the diagrams I found online would open
Old Jan 30, 2012 | 12:06 AM
nj85z28's Avatar
Senior Site Administrator
I did a quick search and from what I've read (quickly) is that the high beams are set in place but the screws will vertically adjust the lowbeams.
Its not quite as simple as just turning the screws either you should adjust properly as recommended. Most manufacturers recommend that you park a certain distance away on a flat surface and measure where the beam falls.
Old Jan 30, 2012 | 2:42 PM
BigDawg's Avatar
Excellent thank you, my lights were a bit low, so I did the garage door 30ft adjustment. I did not know that when you replace bulbs you need to adjust the headlights. There isn`t a horizontal screw or am I over looking the housing.
kellymcg
Jun 30, 2025 8:39 AM
fidde74
Sep 6, 2013 7:13 AM
melat70
Aug 25, 2007 10:01 PM
Occitiger
Apr 25, 2007 8:33 PM
supersam
Cobalt
Aug 18, 2006 12:04 PM
