Uplander 2005-2009
Platform: U-Body
Uplander temperature
Old Feb 7, 2010 | 7:46 AM
Abdo57's Avatar
Default Uplander temperature
When driving my 2007 uplander 80 / 85 mph , The temp.gauge goes slightly above the midway point.
Old Feb 7, 2010 | 8:01 AM
timabrams's Avatar
That is a normal temp, as your engine is working pretty hard to keep you moving at 80. If you slacked off the pedal to 65, the temp would drop. Remember, it takes a larger amount of gas to keep an engine turning at 3000 rpm when in the final gear.
If you are really concerned about it, you can install a lower temp thermostat; however, your economy will suffer. But at 80 mph, your fuel economy isn't that great.
Try 65-70. You should get about 24 mpg. Not bad for a van that has the aerodynamics of a brick.
Old Feb 12, 2010 | 5:11 PM
capucine's Avatar
I have a 2009 uplander and the normal temperature on the needle shows a little bit higher than the the middle mark when the engine has warmed up to its normal temperature. THIS IS THE NORMAL SETTING
biglg
May 21, 2021 10:08 PM
jmadson
Mar 18, 2008 7:49 AM
sbutler430
Jan 22, 2008 1:38 PM
jaymoore74
Colorado
Apr 8, 2007 10:55 AM
tcraig
Sep 7, 2006 1:34 AM
