Venture 1997-2005
Platform: U-Body
A/C problem 2002 Venture
Old May 19, 2010 | 8:02 PM
baby141's Avatar
Unhappy A/C problem 2002 Venture
This is the first time I am having problems with my a/c. The weather is starting to really warm up here and I turned on my a/c. It is blowing warm air. What can the fix be? I'm the one that posted a while ago about leaking antifreeze from the back of the van. I found a few leaks on the pavement near the tail pipe. When I looked underneath, it appeared to be one of the joints leaking. There are three "pipes" that run from the front of the van to the back. I was told this was the heater coil? for the back of my extended van. Could this a/c problem be now be related to the antifreeze leak? The problem is it only leaked like a few times. It hasn't leaked since. Why is this only intermittent leaking? Please help.
Old May 23, 2010 | 7:19 AM
w98seeng's Avatar
The problem can be one of many. It could be as easy as a bad fuse. It might need a recharge of refrigerant. It could be a faulty clutch, a bad compressor, a bad A/C clutch diode, a bad dash switch, or a few other things. You need to bring it in for a proper diagnoses.
slowgo
Feb 12, 2016 10:04 AM
mantta
Mar 1, 2010 1:59 PM
rsmith7964
Oct 27, 2009 6:14 PM
demeop
Jun 26, 2009 8:11 AM
johnhartlove
Dec 2, 2007 7:36 PM
