Couple Ques ....
I have an 02 Venture WB edition.. 1st off, is there a way to check the "check engine soon" light at home? I know Auto Zone will do it free, but I seem to never have time to run up there.
The coolant seems to have a teeny leak as it will start to almost run hot every few months and I have to fill up the reservior (sp?)...any tips??![Frown](https://chevroletforum.com/forum/images/smilies/frown.gif)
Also, the horn just blows by itself sometimes!
It's funny but startles me everytime, has anyone else had that happen and if so, can it be fixed???![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
I'm sorry if these have been asked before, I did go through the forum and didn't see them though.
Thank You!!!
Thank You!!!
ORIGINAL: chevymomof5
hi, this is angie i have had a coolant problem in the past. it was my head gasket leaking some where around the block? if you are looseing water do a pressure check while the van is running. to see where the water is comeing from. my vans water was starting to mix w/ oil when we found the problem this could have blown a gasket causeing my moter to blow. the coast to fix this was $500.00 this was a cheap price for the job. just make sure you find where the water is going this is a common problem for this van. caused from the antifreeze used.... CHANGE antifreeze!! hope this helps??
grinnellbrent
January 7th, 2007 2:06 PM
nyyphily45
November 30th, 2006 6:23 PM
