Venture 1997-2005
Platform: U-Body
Humming noises
Old Jun 15, 2010 | 9:39 AM
1dieselsteve's Avatar
Default Humming noises
I have a question, I own an 02 chevy venture and when it reaches the speed of 40 mph you start to here a humming noise. I have had one bearing replaced but that time the abs light came on. I did check for any kind of movement but nothing was found. can it still be the front bearing?
Old Jun 15, 2010 | 6:21 PM
MDTAHOE's Avatar
Professional Mechanic
Yes it could still be a front bearing. Does it change as you turn the wheel?
Old Jun 15, 2010 | 11:13 PM
No, these noises seem to stay the same can you tell if it were the bearings or cv shafts? No ABS light comes on.
Old Jun 16, 2010 | 8:10 PM
MDTAHOE's Avatar
CV shafts will not make a roaring sound. ABS light rarely ever comes on when the bearing is bad. Feel the tires are they choppy
Old Jun 17, 2010 | 11:23 AM
No, lifted up the van all the way around, started the engine, put in drive, and looked at the rotor as it was turning. it was making some noise but there was also alot of movement were the cv joint comes out from the transaxle.
preppycowboy06
Dec 24, 2012 12:13 PM
cate63
Apr 18, 2008 6:16 PM
pearwear
Apr 1, 2008 8:53 PM
Banddingalls
Cobalt
Mar 18, 2008 8:49 PM
mwhite
Nov 18, 2007 7:01 PM
