more window problems
Have a 2003 Venture, the power windows quit working every now and then. I traced the problem back to a relay under the dash. I had no power at the fuse block so it traced the blue wire back to this relay. Only thing I could find wrong was the voltage on the on relay block was only 10.3 volts ,other relays show battery voltage. Is this not enough to engage the relay? I cant find any diagrams that go back farther than the fuse block. Is there some kind of module that powers this? Does anyone know where I can get more wiring info? If nobody knows anything I am just gonna wire the windows direct to the battery with a fuse, windows do work this way. (it is a beater anyway) Thanks for any help you can give me. Jeff.
Hey ! Perhaps - this information was late. But still ..... This topic has already been discussed at the forum.
https://chevroletforum.com/forum/ven...-not-up-47982/
I know it's a hassle to pull the dash out, almost as if it was designed to be difficult.
