I have an 04 Montana (sister to the Venture) and the Passenger's Sliding Door has stopped working. I would like to try some troubleshooting steps before I tackle a complete overhaul. I am looking for some information on the contact panels on the Door and Door sill.
The contacts on the
Door Sill:
1 2
3 4
5 6
7 8
Door
2 1
4 3
6 5
8 7
Which ones on the sill should have power when the
Open Door button is pushed? (Door open or closed, are they the same)
Close Door button is pushed? (Again are they the same as above)
Also, if I connect a 12 volt power supply (i.e. battery) to the door contacts which ones should open the door and which ones should close the door? this should tell me if the motor is working, correct?
Thanks in advance
Thank you, I will have to sit down and try and follow the schematic. Would you by any chance know which contacts will show power when one of the buttons is pressed?
The fuse (circuit breaker) should be fine as the Driver's Door works fine. When it gets a little warmer, I will check the wiring, thanks again.
Would you know which of the contacts should operate the door? Either on the post or the door, that way I could check and see if there is power to the contacts at the post and if I apply power to the door contact if the motor will work, Again thanks,
