Astro 1985-2005
Platform: M-Body
89 chevy astro problem wont run after hot
Old March 18th, 2009, 5:04 PM
chrisl62's Avatar
Default 89 chevy astro problem wont run after hot
I have an 89 chevy astro with the 4.3l and it will start cold but once warm it will die. I have replaced distributor,Ignition coil, ignition module,Ignition switch, fuel filter,the catalitic is good. so what else could there be to fix this
Old April 5th, 2009, 7:53 PM
chrisl62's Avatar
Default 89 astro wont start
Have ran code scanner but no codes on this. have replaced fuel pump, oil pressure switch, fuel filter, distributor, ignition coil , fuel pump relay, ignition module the engine doesnt get hot just after the motor warms to normal temp it wont start. have tried just about everything I know and no fix yet.
Old April 5th, 2009, 7:58 PM
chrisl62's Avatar
plus I replaced the ignition switch
Old April 5th, 2009, 7:59 PM
chrisl62's Avatar
it will run if it sets for a while but then after a few minutes of run time it just dies and wont start back up catalitic is clear and not getting hot so what else
Old April 6th, 2009, 6:45 AM
chrisl62's Avatar
How often will the fuel pump cycle if i turn the key off and then turn it back on it will only cycle once every few minutes it wont cycle every time u turn key off and on is this right or do you think there is a short
Old April 6th, 2009, 5:36 PM
chrisl62's Avatar
it will die when driving or when idling either now it is starting to die after it runs for about 3-5 minutes but I have replaced fuel pump and filter and relay and oil pressure switch I will check fuel spray and see what it looks like and fuel pressure
Old April 9th, 2009, 6:51 AM
chrisl62's Avatar
well it sprays good and so i check some more stuff and changed plugs the fuel pump wont charge every time you turn key on but I had a guy who came by he said he will buy it for $500 so I sold it to him. Thank You Gary for all your help
ShadeTreeJack
August 2nd, 2014 12:14 PM
bretb2012
July 5th, 2012 9:20 PM
Punisher327
June 26th, 2011 7:56 PM
horsewhispur
August 6th, 2006 5:44 PM
Quick Reply: 89 chevy astro problem wont run after hot
