Help My Chevy Astro keeps stalling.. All suggestions welcome...Running out of Ideas
Hello Everyone ,
First I would like to start off by saying I am a woman (because of my user name everyone assumes I am a guy ) and 2nd I am looking for all helpfull hints and Ideas that could solve my issue with my 1999 Chevy Astro Van (automatic) Rear wheel drive. On mild or damp days I can be driving along the road then all of a sudden all my warning lights come on in the dash. Since before christmas I have been dealing with this stalling issue and it's very dangerous on busy roadways . So far I have replaced the follwing.. Fuel Pump, Fuel Filter, Gas Line in the front, Router, Distributor cap, Power steering pump, Coil. I have had a mechanic hook it up to a diagnostic machine and it tells him that there is no errors. I really depend on my Chevy van for alot of things and well again like I say .. it's not safe when it stalls out in the middle of traffic.
Hope to hear from everyone or anyone soon.
MAC
MAC
Welcome to the forum. When you say "all my warning lights come on in the dash," do you mean like when you first turn the key on, bulb tests and gauge sweeps and all? If so, you have an intermittent electrical power problem with the chief suspect being the ignition switch.
Hello Everyone ,
MAC
MAC
Grrrr I had replied to both of you and for some reason my page timed out... Fudge Ok let me see if I can remember what I all wrote. EinST the lights that I can remember seeing on in the dash were the battery light, check engine light, security light and the ABS light. I will try to remember to pay more attention if it happens again. Stevejohnson48 I always make sure to bring my vehicles to licensed mechanics who are very well known and have a very good service level with recommendation from current customers.... but as far as the serial numbers on the parts I will have to check that out considering that I have the old parts here. I know that there was some wires that were corroded and the mechanic changed them without a cost. I do know that the tech hooked it up the the diagnostic machine and there was 9errors before the fuel filter and the front gas line were changed.. once those two things were done the diagnostic machine said that the errors were all fixed. I even called a friend of mine who is also a licensed mechanic and I was describing to him what I have all changed / whats been happening and he has suggested Distributor, Modul, Bad Relay or even the possible pick up coil. I am going to look into these things to change Hope this answered your questions in your comments Keep your suggestion coming.
This is why eyewitness accounts can't be depended upon in a serious jury trial. Do keep an eye on just what indicators come on, what stay on, and what the gauges do. If the ABS and SECURITY indicators came on briefly, it'll mean something, if they stayed on, it'll mean something else. Basically, what you've said did not prove nor disprove the ignition switch. However, if it's never been replaced and your key chain weighs more than what a couple keys weigh, the ignition switch approaches statistical certainty.
Thank- you
Thanks for the reply and suggestions. I have decided that I will be only using this vehicle around my home so this way here I am not stranded on the side of the road. I will continue to return here for more suggestions for my mechanic. Chow for now
My 1999 Chevy Astro has problems when wet outside
I sort of have the same problem except mine doesn't want to start when its wet or damp outside. If it does start it hesitates until I am going 40MPH Once it warms up or drys it is fine. I have had a total tune up including a new distributor cap. The Chevy dealer said I need a new catalytic converter but didn't think that would cause it to have this problem.
Any suggestions would be appreciated.
Thanks
Janet
Thanks
Janet
