Audio/Visual Electronics Wired up? Got a cool sound system? Discuss all your Audio, Video, and other cool electronics here! Please limit the contents to aftermarket only. If you have questions that pertain to a certain model, post it in a model-specific section.
Ground loop
Old January 2nd, 2009, 12:46 PM
sawyerd's Avatar
Default Ground loop
I've installed headrest DVD monitors in a 2002 Chevrolet suburban with audio through an Fm modulator. I'm getting a ground loop on the audio side, not visible on the video side.
The 12V+ is through the Audio 2 circuit in the fuse block.
Any suggestion on a ground point under the dash or in the center console?
I've tried grounding the framing for the dash itself and to a bolt holding the drivers side seat down. And am still getting alternator whine.
Thanks in advance,
Derek
sloppydawg123
Silverado & Fullsize Pick-ups
February 28th, 2010 9:13 PM
YooperJ
August 17th, 2009 11:27 PM
Mike Sigmond
May 12th, 2009 8:36 AM
sawyerd
January 2nd, 2009 5:08 PM
Quick Reply: Ground loop
