OE Nav upgrade '07 Silverado LT1
Bought a OE NAV radio and have it installed but have yet to install the needed amp. Bought a aftermarket amp, but am having second thoughts that a OE Bose amp and wiring harness might be a better, cleaner fit in the log run. But have a few questions:
Where in the NBS '07 Silverado's w/Bose is the Bose amp mounted?
What are the GM model number(s) for any wiring harness's needed to add a Bose amp to a non-bose setup?
Doing a Bose amp install would eliminate the need for adding a wire from battery and be more plug and play no?
RE: OE Nav upgrade '07 Silverado LT1
Harness would be a body harness (would likely require to replace entire cab harness-I think, not 100%sure). The amp is usually in the center console between the driver and passenger seats.
ctahoe
Audio/Visual Electronics
December 13th, 2008 1:18 PM
