Audio/Visual Electronics Wired up? Got a cool sound system? Discuss all your Audio, Video, and other cool electronics here! Please limit the contents to aftermarket only. If you have questions that pertain to a certain model, post it in a model-specific section.
OE Nav upgrade '07 Silverado LT1
Old January 4th, 2009, 12:26 PM
ctahoe's Avatar
Default OE Nav upgrade '07 Silverado LT1
Bought a OE NAV radio and have it installed but have yet to install the needed amp. Bought a aftermarket amp, but am having second thoughts that a OE Bose amp and wiring harness might be a better, cleaner fit in the log run. But have a few questions:
Where in the NBS '07 Silverado's w/Bose is the Bose amp mounted?
What are the GM model number(s) for any wiring harness's needed to add a Bose amp to a non-bose setup?
Doing a Bose amp install would eliminate the need for adding a wire from battery and be more plug and play no?
Old January 4th, 2009, 8:24 PM
charlie pachanga's Avatar
Default RE: OE Nav upgrade '07 Silverado LT1
Harness would be a body harness (would likely require to replace entire cab harness-I think, not 100%sure). The amp is usually in the center console between the driver and passenger seats.
ctahoe
December 13th, 2008 1:18 PM
biglg
January 22nd, 2008 8:16 PM
jazzson007
Avalanche
July 12th, 2007 8:53 PM
kbeas
May 26th, 2007 9:40 AM
Quick Reply: OE Nav upgrade '07 Silverado LT1
