Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1991 Chevy Corsica 3.1L V6 engine stalling issues
Old October 17th, 2016, 1:32 PM
Jason Figueroa's Avatar
Unhappy 1991 Chevy Corsica 3.1L V6 engine stalling issues
I have a 1991 Chevy Corsica, 3.1L V6 engine, that has been going through some stalling issues. My buddy, who has some knowledge of car repairs believed it was the throttle position sensor. I bought a new one and replaced it. It worked for a day, but it stalled again. My buddy then believed it was the mapping sensor. I replaced that one and took it out for a test drive. After driving for over 20 miles, it again stalled and this time a "service engine light" turned on.. The engine runs and hesitates at times when it is parked. Once I put the car into drive, it stalls. My friend then believes that it must be the fuel pump. I tested out the fuel pressure, and the gauge places it at 39 psi when this engine is supposed to be between 41-47 psi. My friend recommended that fuel pump should be replaced. After we replaced it, the engine still stalled when put into drive. I gave up at that point and took the car to a mechanic. The mechanic said it was the catalytic converter and replaced it. They took it out for a test drive and said it was fixed. I picked up the car, and it does not sound like the car was entirely repaired. About 20 miles out, the car, will stall when I slow it down, and I have to play with the gas pedal to slowly get the vehicle going. At times while accelerating, the engine stalls. I would have to pull over, shut the car off, and turn it back on a few times just to get moving. Even when braking the car to full stop, the car will stall, when I hit the gas pedal. The mechanic texted me, asking how the car was running. After I had texted him back that the car still has stalling issues, that was the end of the conversation.
I want to take the vehicle to another mechanic, but I want to find one who can at least know what the problem is. I asked my buddy if the PCV valve might need to be replaced, but he doesn't think so. If anyone reads this, had this similar issue and believed they know what the problem is, please feel free to give pointers.
Thanks.
Old October 20th, 2016, 5:06 PM
kevinkpk's Avatar
Fuel, and fuel filter
Old March 26th, 2017, 10:38 AM
davyjones365's Avatar
What did you find to cure your problems . I'm having similar problems with a 1994 Lumina , with the 3.1 engine. Thx. Dave.
Old June 9th, 2023, 9:49 PM
tred121's Avatar
Default any luck
been having the same issue with a either 91 corsica or 90 car door says one year manuel says another
InjuredPride
January 13th, 2020 10:31 PM
cdelta1975
December 4th, 2019 12:56 AM
guamboy
October 21st, 2013 4:33 AM
Fitz
Camaro
October 9th, 2011 7:05 PM
vickilev10
January 7th, 2011 10:47 AM
Quick Reply: 1991 Chevy Corsica 3.1L V6 engine stalling issues
