2016 Camaro
Platform: F-Body & Zeta.
86 z28 305 tpi
Old December 23rd, 2012, 1:09 PM
Darren Fargo's Avatar
Default 86 z28 305 tpi
Hello my SAVIORS. ( I hope) I have a 305 TPI set up. In the summer car wont idle till it is warmed up. Then I shut it off and restart. It runs perfect after that until I shut it off and it cools down. Now winter is here and it will start easy but runs about 2000rpm for 60 seconds then when it trys to idle down it dies. when i restart it runs really rough and blows black smoke like it is really rich. I have changed the temp sensor but no change. It shows these codes, 15 (coolant temp sensor circuit fault or High voltage) I have changed this sensor. Code 21 ( Throttle Position Sensor- High Voltage). and code 33 (MAF sensor -system voltage high during idle).
I hate just replacing parts PLEASE help if you have had similiar problem.
Thanks
marcolanz
August 8th, 2012 3:50 PM
verr1908
November 20th, 2010 2:46 PM
87Z28
Camaro
February 14th, 2010 5:32 PM
rich
Computer, Ignition, & Fuel Systems
November 2nd, 2006 12:07 PM
Quick Reply: 86 z28 305 tpi
